2024
Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
View new features for Radioss 2024.
Current Radioss format uses the 12x extension format.
Engine Keyword In this group keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
Engine Keyword
Engine Keyword Generate H3D contour output results for /BEAM beam elements.
Engine Keyword Compress the H3D file.
Engine Keyword Writes the H3D results file at specified output frequency.
Engine Keyword Write additional animation time steps to the H3D file when a sensor in the list is activated.
Engine Keyword Generate H3D contour output results for nodes.
Engine Keyword Define which parts will be saved in the H3D file. The H3D file will only contain the model and result data for the listed part_IDs.
Engine Keyword Display all RBE2 in a single part.
Engine Keyword Display all RBE3 in a single part.
Engine Keyword Display all rigid bodies (/RBODY) in a single part.
Engine Keyword Generate H3D contour output results for /QUAD quad elements.
Engine Keyword Generate H3D contour output results for /SHELL and /SH3N shell elements.
Engine Keyword Generate H3D contour output results for /BRICK, /BRIC20, /TETRA4, /TETRA10 solid elements and /BRICK, /PENTA6, /SHEL16 thick shells.
Engine Keyword Generate H3D contour output results for SPH.
Engine Keyword Generate H3D contour output results for /SPRING spring elements.
Engine Keyword Write additional name description to the H3D file content.
Engine Keyword Generate H3D contour output results for /TRUSS truss elements.
Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, and so on) for different entities (shell, brick, beam, airbag, interface, and so on) during the computation.
Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, and so on) in a state file (STA-File).
Engine Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
This manual provides a list of LS-DYNA input files available in Radioss.
This manual contains the description of the keywords for the Radioss Multi-Domain.
