*CONSTRAINED_RIGID_BODIES
LS-DYNA Input Interface KeywordDefine rigid bodies assembly.
(1) (2) (3) (4) (5) (6) (7) (8)
Part_M_ID Part_S_ID Iflag
Definition
Part_M_ID Part identifier with main rigid material.
(Integer)
Part_S_ID Part identifier with secondary rigid material.
(Integer)
Iflag Flag for merged rigid body property (used if Part_M_ID is PART_INERTIA).
= 0 (Default)
Rigid body center of gravity, mass and inertia is recomputed with all merged rigid bodies .
= 1
Rigid body center of gravity, mass and inertia keeps the value defined in Part_M_ID.
(Integer)
  1. This keyword maps to /MERGE/RBODY.
