*CONTACT_ERODING_NODES_TO_SURFACE
LS-DYNA Input Interface KeywordDefine nodes to surface contact interface.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONTACT_ERODING_NODES_TO_SURFACE_{OPTION3} | |||||||
If OPTION3 = ID, insert the following line
| inter_ID | Title | ||||||
| SSID | MSID | SSTYP | MSTYP | ||||
| FS | FD | DC | Tstart | Tstop | |||
| SFS | SFM | SST | MST | SFTS | SFMT | FSF | |
| Blank card | |||||||
Optional Card A
| SOFT |
Definition
| OPTION3 |
| inter_ID | Contact interface
identifier. (Integer) |
| Title | Contact interface
title. (Character, maximum 70 characters) |
| SSID | Secondary set or part
| MSID | Main set or part
| SSTYP | Input secondary set type.
(Integer) |
| MSTYP | Input main set type.
(Integer) |
| FS | Static friction
coefficient. (Real) |
| FD | Dynamic friction
| DC | Exponential decay coefficient. | |
| Tstart | Start time. (Real) |
| Tstop | Stop time. Default = 1E+30 (Real) |
| SFS | Secondary stiffness scale
factor. (Real) |
| SFM | Main stiffness scale
factor. (Real) |
| SST | Secondary maximum gap
value. (Real) |
| MST | Main maximum gap
value. (Real) |
| SFTS | Secondary contact gap
scale. (Real) |
| SFMT | Main contact gap
scale. (Real) |
| FSF | Coulomb friction coefficient scale factor | |
| SOFT | Contact stiffness definition flag.
(Integer) |
- This keyword maps to /INTER/TYPE25.
