/RUN
Engine Keyword Identifies the run number.
/RUN/Run Name/Run Number/Restart Letter
Tstop
Definition
| Run Name | Character variable that
identifies the problem solved. (Character, minimum 4; maximum 80 characters) |
| Run Number | The run numbers 1, 2, ... (Integer) |
| Restart Letter | (Optional) Restart file identifier
| Tstop | Final time for the run. |
- If using MADYMO- Radioss coupling, the final run time taken into account is not Tstop, but the final time defined in MADYMO input.
- Restart letter could be I, J,
K, ...
- = J
- Run Restart with Runname_0001_J.rst
- = K
- Run Restart with Runname_0001_K.rst
These Restart files are saved in previous run by using /RFILE.
