RD-E: 2600 Ruptured Plate
A metallic thick plate is perforated by a rigid sphere. Simulation of the rupture uses different failure models.
The study is divided into three parts:
- Rupture using a damage model in LAW27
- Failure using the Johnson-Cook model
- Advantage of Forming Limit Diagram as a failure model
The sensitivity of the results for the different failure models is demonstrated.
