Engine Subroutine FnnLAW for Solid Elements
This subroutine calculates the criteria of failure model.
Use the float external function
FINTER (shown below) to get the
value Y of the function for the abscissa
X:Y=FINTER(IFUNC(I),X,NPF,TF,DYDX)- Variable
- Description
- Y
- Interpolated value
- X
- Abscissa value of the function
- I
- The ith user’s function
- DYDX
- Slope
- NPF, TF
- Private function parameters
Arguments
The arguments list of FnnLAW
is:
C----------------------------------------------------------------------------
SUBROUTINE FnnLAW (
1 NEL ,NUPARAM ,NUVAR ,NFUNC ,IFUNC ,
2 NPF ,TF ,TIME ,TIMESTEP ,UPARAM ,
3 NGL ,NOT_USE_I1 ,NOT_USE_I2 ,NOT_USE_I3 ,NOT_USE_I4,
4 EPSPXX ,EPSPYY ,EPSPZZ ,EPSPXY ,EPSPYZ ,EPSPZX ,
5 EPSXX ,EPSYY ,EPSZZ ,EPSXY ,EPSYZ ,EPSZX ,
6 SIGNXX ,SIGNYY ,SIGNZZ ,SIGNXY ,SIGNYZ ,SIGNZX ,
7 PLA ,DPLA ,EPSP ,UVAR ,OFF ,
8 DELTAX, VOLN, UELR, NOT_USED4 ,NOT_USED5 )
Definition
| Argument | Format | Description |
| NEL | Integer read only scalar | Number of elements per group. In the Engine subroutine, the element data are treated by groups for vectorization purposes. |
| NUPARAM | Integer read only scalar | Size of user parameter array. |
| NUVAR | Integer read only scalar | Number of user integration point element variables. |
| NFUNC | Integer read only scalar | Number of functions used for failure model materials. |
| IFUNC | Integer array read only | Array of size NFUNC containing function indexes. |
| NPF | Integer array private data | Array used by FINTER (float external
functions). |
| TF | Float array private data | Array used by FINTER (float external
functions). |
| TIME | Float read only | Current time. |
| TIMESTEP | Float read only | Current time step. |
| UPARAM | Float array read only | User failure parameter array of size NUPARAM. |
| NGL | Integer array read only | Array of size NEL containing the external element number. |
| EPSPXX, EPSPYY, EPSPZZ, EPSPXY, EPSPYZ, ESPPZX | Float array read only | Array of size NEL containing strain rates in directions XX, YY, and ZZ and strain rates in directions XY, YZ, and ZX. |
| EPSXX, EPSYY, EPSZZ, EPSXY, EPSYZ, EPSZX | Float array read only | Array of size NEL containing strain in directions XX, YY, and ZZ and strain rates in directions XY, YZ, and ZX. |
| SIGNXX, SIGNYY, SIGNZZ, SIGNXY, SIGNYZ, SIGNZX | Float array read write | Array of size NEL containing stress in directions XX, YY, ZZ, XY, YZ, and ZX. |
| PLA | Float array read only | Array of size NEL containing equivalent plastic strain. |
| DPLA | Float array read only | Array of size NEL containing incremental equivalent plastic strain. |
| EPSP | Float array read only | Array of size NEL, equivalent of strain rate. |
| UVAR | Float array read write | Array of size NEL*NUVAR containing integration point element variables. |
| OFF | Float array read write | Array of size NEL containing deleted
element flags.
| DELTAX | Float array read only | Array of size NEL containing characteristic element length. |
| VOLN | Float array read only | Array of size NEL containing current element volumes. |
| UELR | Float array read write | Array of size NEL, containing the number of IP’s in which the failure criteria is satisfied for all elements. |
| NOT_USE_I1, NOT_USE_I2, NOT_USE_I3, NOT_USE_I4 | Integer scalar | Not used. Can be used in the future. |
| NOT_USED4, NOT_USED5 | Float scalar | Not used. Can be used in future. |
