Contacts in SimSolid
Changes to contacts for SimSolid analysis.
Contacts are defined differently depending on which solver you use, which may result in a greater number of contacts. If you switch between solvers, you will need to open the Contacts tool, click Find, and then redefine contacts using the appropriate method.
You can find and review any disconnected groups of parts using the Disconnected Groups tool on the Contacts icon.
Tip: To find and open a tool, press
Ctrl+F. For more information,
see Find and Search for Tools.
Note: This tool only appears when the SimSolid solver has been enabled in the
Preferences.
