Create Buckling Responses
Create buckling load factor responses for the entire model.
From the Design Explorer ribbon, select the Responses
tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Use the dropdown menu on the left side of the guide bar to select Buckling.
On the guide bar, click
to create the response.
- Optional: Make any desired modifications to the created response in the microdialog.
