Scatter Plots
Plot exploration inputs and outputs.
From the Design Explorer ribbon, Evaluate tool group, click the
Results Explorer tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.The Results Explorer browser opens. -
In the Results Explorer browser, click the Scatter Plot
icon
- Select the desired X-axis value and the desired Y-axis value(s).
- Optional:
Select constraints to plot as datum lines.
Note: Checking Show Violated will color plot points red where corresponding runs violate the given constraint.
