Export DXF/DWG
Export a sketch as a .dxf or .dwg file.
On the Sketching ribbon, select the Export DXF/DWG
icon.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - In the dialog box, select a folder, name your file, choose between .dxf or .dwg, and then click Save.
