Mass Calculation
Mass calculation allows masses to be calculated and displayed in the Model Browser.
To improve overall performance, when a CAD file is imported the mass sizes are not calculated and are shown as ** in the Model Browser.
- To display mass in the Model Browser, right-click the column header in the Model Browser.
Under Property, select the Mass checkbox.
Click OK.
- Click the Calculate button to display the mass of a part. A nonzero mass indicates a solid object.
Note: You can override a selected part's mass in the Property Editor. This
will affect measure weight calculations and motion calculations, but not structural
analysis calculations.
