Show, Hide, and Isolate
Show, hide, and isolate objects in the modeling window using keyboard shortcuts.
To | Do this | Note |
Show/hide selected objects |
You can also show or hide objects by:
Isolate selected objects (parts, assemblies, sketches, faces, and reference entities) |
Isolating an object zooms in and temporarily hides all other objects. |
Show all/hide all objects |
Reverse the selection |
Temporarily turn selected parts transparent | Hold down Ctrl. |
Show/Hide Mode
Show or hide objects in the modeling window.
In the view controls, select Show/Hide Mode
Select one of the following options:
- Parts: Show/hide parts.
- Faces: Show/hide faces.
You can do the following:
To Do this (Parts) Do this (Faces) Hide Click the parts. Click the faces. Show Hold down Shift while clicking the parts. Hold down Shift while clicking the faces. Hide all Select Hide All .
Select Hide All .
Show all - Select Show All
- Press A.
- Select Show All
- Press Shift+A.
Hide currently visible objects and show currently hidden objects Select Reverse Visible .
Isolate N/A Select the faces, then select Isolate .
Tip:- The mouse cursor indicates whether the object you click will be
shown
or hidden
- Select Show All
- Right-click to exit the tool.
