Workspace
The Inspire workspace includes the ribbon, modeling window, legend, and status bar.
![](../../../images/figures/shared/overview_Inspire.png)
The Inspire workspace is organized into the following areas:
- The ribbon includes both menus and ribbon tabs with icon groups.
- The modeling window is where you interact with your model, and includes the view controls in the lower left corner.
- The legend displays parts by color-coded categories and allows you to hide and isolate them.
- The status bar displays model status information and includes the snaps filter and unit system selector.
Customize the Workspace
Change the appearance of the workspace including the color scheme, language, and various elements of the user interface.
- Select the File menu.
- Click the Preferences button.
- Select Workspace and change the settings as desired.
- Click OK.
Customize the Ribbon
Create one or more custom tabs on the ribbon and populate them with your favorite tools.
Click the
icon on the ribbon to create a custom tab.
Drag icons from the standard tabs to the custom tab. If an icon contains
multiple tools, all of the tools on the icon are copied to the custom tab.
You can rename or delete the custom tab by right-clicking the tab name, and then selecting Rename or Delete. To delete multiple custom tabs simultaneously, right-click empty space on the ribbon, select Delete Custom Pages, select the tab names, and then click Delete.
Organize the tools on the custom ribbon.
- To move an icon, drag the icon.
- To rename an icon, right-click the icon, select Rename, and then type the new name.
- To delete an icon, right-click the icon, and then select Delete.
To export a custom tab, right-click the tab name, and then select
Export. To export multiple custom tabs
simultaneously, right-click empty space on the ribbon, select Export
Export.
The custom tabs are exported as an .xml file.
Customize Keyboard Shortcuts
Assign custom keyboard shortcuts to specific functions in the Preferences.
- Click the Preferences button to open the Preferences window.
- Select Keyboard Shortcuts.
- Click on the value for a command to change the assigned keyboard shortcut.
- Click OK.
