Rounded Pattern
Checks patterns in FPCB are rounded.
- Target Object Definition: Define target patterns.
- All Patterns: All patterns will be target patterns.
- Pattern with specific Area: Target patterns will be patterns in certain area.
- Layer Selection for Area Definition: To define area, select the layer from the layer list.
- Option
- Excluding Patterns near Pads or Vias: Check the patterns rounding in
area, expanded from pads or vias.
Figure 1.- Area Expand from Pads: Set pad expansion distance.
- Area Expand from Vias: Set via expansion distance.
