Thermal Transient
Thermal transient analysis is used to capture the thermal behavior of a system over a specific span of time. Boundary conditions vary with time, but the material properties remain constant.
Setup
  1. Specify the time span.
  2. Specify the number of output timesteps.
  3. Specify the initial temperature.
  4. Optional: Check the temperature dependent properties to perform nonlinear thermal transient analysis.
