2024
Create an analysis for your project.
Thermal analysis predicts how thermal effects propagate through the model. Steady state and thermal transient analyses are supported.
Allows importing temperature at various points of the model for various load steps.
View new features for SimSolid 2024.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Evaluate your design in real-time using SimSolid dynamics analysis.
Thermal analysis assumes a linear steady state condition.
Fatigue analysis is intended for predicting life of structures under cyclic loading.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
Solved verification models.
