Imported Temperature
Allows importing temperature at various points of the model for various load steps.
- In the project tree, open the thermal imported Analysis Workbench.
- Browse to the desired .csv file in the File Explorer.
Click Open.
The imported loads are mapped at points specified in the .csv . The points can be mapped not just on the surface but also inside the part.
Imported temperature .csv
file format fields:
- ID (optional) – Alphanumeric value. Used to identity a specific point.
- X, Y and Z – Numeric values. Spatial location used to map temperature to the nearest point on a face.
- Temperature1, Temperature2,…TemperatureN – Numerical value. T1, T2,…TN is also acceptable. Temperature at various load steps.
ID(optional),X,Y,Z,Temperature1,Temperature2,Temperature3
0,-10,30,0,50,60,55
1,-11,30,0,52,72,46
2,-12,30,0,44,35,64Note: Imported file follows the input units set
in SimSolid.
