Inertia Relief
Simulate deformations and stresses in cases where you have an unconstrained structure to which an active load is suddenly applied.
- On the Project Tree, open the Analysis Workbench.
In the workbench toolbar, click .
The inertia relief will appear in the Project Tree under Analysis > Loads&Constraints.Note: Inertia relief cannot be combined with other translational or rotational inertia loads. Also no immovable, sliding or hinge constraints can be defined.
