Import Geometry
Workflow tips for geometry import in SimSolid.
Use Parasolid reader for best results.
- This reader only brings in solid geometries ignoring other data.
- Parasolid files is preferred over step files.
- With NX, use native geometry files.
- With CATIA, 3dxml files are lighter and faster to import.
Figure 1. Settings > Geometry import settings
Use Parasolid and Spatial (CATIA V5 and V6).
This reader will use spatial reader for CATIA V5 and V6 formats.
If you are using the legacy reader, be cautious:
- Always export geometry in assembly/global coordinates, so they are positioned correctly.
- If part instances exist, save a copy of the part that can be imported into SimSolid.
