SS-V: 2070 Cantilever Beam
Test No. VM08 Perform normal mode dynamic analysis of a cantilevered beam.
Definition
The left end is fully constrained; the back face has a slider constraint to remove the third dimension.
The units are SI.
The material properties are:
- Properties
- Value
- Modulus of Elasticity
- 2e11 N/m2
- Poisson's Ratio
- 0.3
- Mass density
- 8000 kg/m3
Results
The following table summarizes the
modes.
| Reference Solution | SimSolid | % Difference | |
| Mode 2 [Hz] | 6.327 | 6.323 | -0.06% |
| Mode 3 [Hz] | 17.720 | 17.683 | -0.20% |
| Mode 4 [Hz] | 34.720 | 34.596 | -0.36% |
| Mode 5 [Hz] | 57.390 | 57.068 | -0.56% |
| Mode 6 [Hz] | 85.730 | 85.024 | -0.82% |
1 NAFEMS Finite Element
Methods & Standards, Abbassian, F., Dawswell, D. J., and Knowles, N. C. Selected
Benchmarks for Natural Frequency Analysis Test No. 71. Glasgow: NAFEMS, Nov.,
1987.
