Graphical View of Job Progress and Results
Job Status
In Accelerator, each job goes through a number of states until completion.
The states are described in the following table:
Status Color Description
Idle BlueViolet If the node is a job, either it has not been run successfully yet or it needs to be run again, because one of its inputs has been modified since the last time the job was executed. If the node is a file, it is the output of a job that is not Idle.
Queued Light blue The job is scheduled to be run. It may be already queued or it will go in the queue as soon as all its inputs are ready.
Running Orange The job is currently being retraced; it has been dispatched to one of the taskers. All the outputs of such a job are either RETRACING or RUNNING.
Done Green If the node is a job, it has run successfully. If the node is a file, it is up-to-date with respect to all other files and jobs on which it depends.
Failed Red The job ran and failed.
Transfer Cream The job is being transferred to another cluster and it is not yet running.
Suspended Pink The job was running (or retracing) and one of the processes belonging to the job is currently suspended.
Sleeping Black Either the job caused an output conflict upon submission (bad dependencies) or the job was not reclaimed by any tasker upon crash recovery.
Withdrawn Gray A job has been withdrawn after dispatching, such as by the preemption daemon.
Note: This status occurs rarely and tends to be hard to observe.
The normal sequence for a successful job is Idle > Queued > Running > Done
The normal sequence for a failing job is Idle > Queued > Running > Failed
Set Status
The status of a set is computed from the status of the nodes it contains.
The status of a set is computed from the Node Status of the nodes it contains. If the set is empty, it's status is EMPTY. Otherwise, the status is determined by the dominant status according to the following ranking:
  1. RUNNING
  2. RETRACING
  3. FAILED
  4. INVALID
  5. UNKNOWN
  6. MISSING
  7. DELETED
  8. SLEEPING
If at least one node is RUNNING, then the set itself is RUNNING. Otherwise, if at least one node is RETRACING, then the whole set is RETRACING and so on.
In particular, if the set status is VALID (that is, green), then the set has no INVALID, FAILED, RETRACING or RUNNING nodes.
The utility vovset can be used to create, modify, recompute, destroy sets.
