Submitted Job Information Display
By default, nc run provides information when a job is submitted.
% nc run sleep 10
Fairshare= /time/users.andrea
Resources= macosx CPUS/1 RAM/500
Env = SNAPSHOT(vnclogs/snp/joe/macosx/env27227.env)
Command = vw sleep 10
Logfile = vnc_logs/20130220/104930.33137
JobId = 024609542
- FairShare: the FairShare ranking of this job.
- Resources: the resources used to run this job: the machine, number of CPUs, amount of RAM, and so on.
- Env: the environment in which the job was submitted.
- Command: the command that was used to execute this job.
- Logfile: the name of the logfile.
- JobID: the unique identifier of this job.
nc run sleep 10 -v 2
.Verbose Level | Effect |
0 | Silent: no output is generated |
1 | Only the job ID is displayed |
4 | Default level |
9 | Very verbose |
