The autoforget flag sets up a job to automatically be forgotten by the system after a
certain time, (not including suspension time) if and only if the job is done, failed, or
idle. Jobs that are scheduled, running, suspended or transfer are never autoforgotten.
Global auto-forget Parameters
There are three different auto-forget parameters:
- autoForgetValid
- autoForgetFailed
- autoForgetOthers
In
Accelerator, the autoforget flag is set by default, which can
be unset by using the option
-keep in
nc run. In Flow Design
Language (FDL), the variable
make(autoforget) controls the
flag.
- The autoforget flag on the job is true
- The job is done, failed, or idle.
Jobclass Specific auto-forget
- The job belongs to a jobclass with the
AUTOFORGET property set to a positive value.
Note: The autoforget flag on the job is irrelevant.
If a jobclass has a specific auto-forget property, then the
jobs in that jobclass will be forgotten after that
specified time.
For example, to set the autoforget property on a
jobclass
called
abc, use the
vtk_jobclass_set_autoforget
API:
% nc cmd vovsh -x "vtk_jobclass_set_autoforget abc 2m"
To disable this functionality for a
jobclass, set the value
of autoforget to a non-positive value, such as:
% nc cmd vovsh -x "vtk_jobclass_set_autoforget abc 0"
Auto-forget Log Files
If the parameter
autoForgetRemoveLogs is true and the parameter
disablefileaccess is false, the
vovserver tries to delete the log file of the jobs that are being
auto-forgotten. The success of the deletion depends on the file permissions.
Note: Accessing files makes the vovserver vulnerable to NFS
problems.
Auto-forget Examples
For this example, the default autoforget policy is to forget jobs after 1h. Other
jobs in the
jobclass "Regression" should be retained for
10days. Submit the jobs with the
-keep option (no autoforget flag)
and then set the AUTOFORGET property in the set
Class:Regression
to
864000.
### Done by an ADMIN
% nc cmd vovsh -x 'vtk_jobclass_set_autoforget Regression 10d'
% nc run -C Regression -keep ./my_test
Conversely, if the retention policy keeps the jobs for a long time (such as 3 days),
some jobs in the
jobclass "Quick" may be set to be
forgotten more promptly, (such as after 5m) of completion. In this case, set the
jobclass set as follows:
% nc cmd vovsh -x 'vtk_jobclass_set_autoforget Quick 5m'
