Node Fields
Each node in the trace has field attributes.
- Boolean fields, which take value in the set (0,1)
- Integer fields, which take any 32-bit signed integer value
- String fields, which take a null-terminated string value.
The fields are used in the Selection Rules and in Formatting Strings. The field names are not case-sensitive. For
example, the rules IsJob
and isjob
are
equivalent.
% vovshow -fields
Incompatible Fields
Some fields make sense only for one type of nodes. For example, the field NAME makes sense for files but not for jobs, while the field COMMAND makes sense for jobs but not for files. A field is considered incompatible for a node if it does not make sense for that node. This notion of incompatible fields is important in the construction of selection rules and formatting strings.
Fields List
Field Name | Field Type | Applies To | Description |
AGE | Integer (duration) | Nodes | Age in seconds of a job or of a file. |
AGEPP | String | Nodes | Pretty-printed version of age of a job or of a file. |
ANNOTATIONS | Integer | Nodes | Number of annotations attached to the node. |
AUTOKILL | Integer (duration) | Jobs | Time before a job is automatically killed. |
AUXRESOURCES | String | Jobs | Additional resources assigned to a job by the server. |
BUCKETID | String | Jobs | The internal ID of the bucket object that contains the specified job. |
CHOSENTASKERID | String | Jobs | If a job must go to a specific tasker, the ID of that tasker. |
COMMAND | String | Jobs | The command line for the job. |
COMMANDLENGTH | Integer (size) | Jobs | The length of the command line for the job. |
CPUPROGRESS | Integer (percent) | Jobs | The percent of CPU time used by a jobs, including all its children, in the last sampling interval. This number can be greater than 100 if the job is running on a multi CPU machine. If CPUPROGRESS is zero, the job is stuck, probably waiting for input or for a license. |
CPUTIME | Integer (milliseconds) | Jobs | The CPU time used by the job, in milliseconds, including all its children. This is a 64-bit number. |
CURRAM | Integer (MB) | Jobs | The current amount of RAM used by the job, in MB |
CURREAD | Integer (bytes) | Jobs | The current number of input I/O events for the job, in bytes. |
CURVM | Integer | Jobs | The current amount of virtual memory used by the job, in MB |
CURWRITER | Integer (bytes) | Jobs | The current number of output I/O events for the job, in bytes. |
CWD | String | Jobs | The current working directory for the job. |
DB | String | Files | The Databases of a file. |
DIR | String | Nodes | Same as CWD. |
DISPATCHDATE | Integer (timestamp) | Jobs | The time the job has been dispatched to a tasker. This is relevant for indirect taskers, where the DISPATCHDATE may be significantly different from the START time due to latency in the secondary queue. |
DURATION | Integer (duration) | Jobs | The duration of a job, in seconds. |
DURATIONPP | String | Jobs | The duration of a job ID in pretty format. |
ENDDATE | String | Jobs | The end date of a job in string format. |
ENDED | Integer (timestamp) | Jobs | The end date of a job in integer format. If the job is still running or retracing, this field has the value 0 (see Ended2 for a different value). |
ENDED2 | Integer (timestamp) | Jobs | The end date of a job in integer format. If the job is running or retracing, this field returns the current time stamp (see ENDED for a different value) |
ENV | String | Jobs | The environment of a job. |
ENVARGS | String | Jobs | From the environment string, all the words after the first. |
EXECHOST | String | Jobs | The execution host of the job. |
EXITSTATUS | Integer | Jobs | The Exit Status of a job. |
EXPDUR | Integer (duration) | Jobs | (OBSOLETE! Use XDUR instead) Expected duration of a job, in seconds |
EXPDURPP | String | Jobs | (OBSOLETE! Use XDURPP instead) Expected duration, pretty printed. |
FAILCODE | Integer | Jobs | A mask of values indicating why a job failed. |
FLAGS | String | Nodes | Obsolete. Not supported any longer. |
FSEXCESS | Integer | Jobs | This is essentially (FSHISTORY - FSTARGET) + (FSRUNNING - FSTARGET). See also FSEXCESSRUNNING and FSEXCESSHISTORY |
FSEXCESSHISTORY | Integer | Jobs | This is essentially (FSHISTORY - FSTARGET). See also FSEXCESS. |
FSEXCESSRUNNING | Integer | Jobs | This is essentially (FSRUNNING - FSTARGET). See also FSEXCESS. If the number is positive, that means that the group to which the job belongs has more running jobs than it should. |
FSEXCESSRUNNINGLOCAL | Integer | Jobs | VovPreemptRule -rulename SOMENAME \ ... -preempting "FSEXCESSRUNNINGLOCAL<0" \ -preemptable "FSEXCESSRUNNINGLOCAL>0 JOBCLASS==@JOBCLASS@ FSRANK9>@FSRANK9@" \ ... |
FSEXCESSRUNNINGLOCAL1 | Integer | Jobs | Similar to FSEXCESSRUNNINGLOCAL but uses the balance of running jobs at one level above the local. |
FSEXCESSRUNNINGLOCAL2 | Integer | Jobs | Similar to FSEXCESSRUNNINGLOCAL but uses the balance of running jobs at two levels above the local. |
FSEXCESSRUNNINGLOCAL3 | Integer | Jobs | Similar to FSEXCESSRUNNINGLOCAL but uses the balance of running jobs at three levels above the local. |
FSEXCESSRUNNINGLOCALCOUNT | Integer | Jobs | This is number of jobs corresponding to FSEXCESSRUNNINGLOCAL. |
FSEXCESSRUNNINGLOCALCOUNT1 | Integer | Jobs | This is number of jobs corresponding to FSEXCESSRUNNINGLOCAL1. |
FSEXCESSRUNNINGLOCALCOUNT2 | Integer | Jobs | This is number of jobs corresponding to FSEXCESSRUNNINGLOCAL2. |
FSEXCESSRUNNINGLOCALCOUNT3 | Integer | Jobs | This is number of jobs corresponding to FSEXCESSRUNNINGLOCAL3. |
FSGROUP | Integer | Jobs | The FairShare group that the job belongs to. |
FSHISTORY | Integer | Jobs | The actual share in the FairShare window for the FairShare group, multiplied by 10,000. |
FSRANK | Integer | Jobs | The FairShare rank of the FairShare group to which the job belongs, or -1 if the FairShare group has no rank. (See also FSRANK9) |
FSRANK9 | Integer | Jobs | This is the same as FSRANK, except that the value returned for groups that have no FairShare rank is 9,999,999 instead of -1. |
FSRUNNING | Integer | Jobs | The actual share of all running jobs for the FairShare group, multiplied by 10,000. |
FSRUNNINGCOUNT | Integer | Jobs | The current number of running jobs for the FairShare group of the job. |
FSSUBGROUP | String | Jobs | The part of the FairShare group after the colon. |
FSSUSPENDEDCOUNT | Integer | Jobs | The current number of suspended jobs for the FairShare group of the job. |
FSTARGET | Integer | Jobs | The FairShare target for the FairShare group to which the job belongs. The target, which is normally a fracsional number less than 1.0, is multiplied by 10,000 to yield the FSTARGET. For example, a group that has a target of 30%=0.3 will have a FSTARGET of 3,000. |
FSTOKENS | Integer | Jobs | An integer multiplier for the contribution of the job to the FairShare (e.g. a fstokens value of 2 means that the job counts as 2 "normal" jobs) |
FSUSER | String | Jobs | The user component of a FairShare node (i.e. the component right after the dot '.' , if it exists) |
GRABBEDRESOURCES | String | Jobs | The list of resource maps that have been grabbed in order to dispatch a job to a tasker. This is valid only for RUNNING and RETRACING jobs, and the value of the field may change over time due to reconciliation of resources. See also the GRABBEDRESOURCESO field, which is available for jobs even after completion. |
GRABBEDRESOURCESO | String | Jobs | The original list of grabbed resources when a job was last dispatched to a tasker. For RUNNING and RETRACING jobs it is best to look at GRABBEDRESOURCES instead. The final letter is an "oh" for Original. |
GRABBEDTOOLS | String | Jobs | Obsolete: Only for running jobs |
GROUP | String | Jobs | The group of a job. This is different from OSGROUP, which is used to specify the group permissions for the job. |
HASANNOTATIONS | Boolean | NODES | True if the node has Annotations. |
HASINPUTCONFLICT | Boolean | JOBS | True if job failed on an input conflict. |
HASINPUTS | Boolean | NODES | True if a node has one or more inputs. |
HASOUTPUTCONFLICT | Boolean | JOBS | True if job failed on an output conflict. |
HASOUTPUTS | Boolean | NODES | True if a node has one or more outputs. |
HASPROFILE | Boolean | JOBS | True if job collects profile information like RAM and CPU usage at runtime (see option -profile in nc run) |
HASRUNINFO | Boolean | JOBS | Obsolete: always 0. |
HOST | String | JOBS | The host that executed a job. |
ID | String | NODES | The ID of a node. This field is of type "string" and is shown with leading zeroes (e.g. "000123456"). Contrast this with the field IDINT which is of type "integer". |
IDINT | Integer | NODES | The integer version of the Vovid of a node. Contrast this with the field ID which is of type "string" |
INPUTS | Integer | NODES | The number of inputs of a node. |
ISAUTOFLOW | Boolean | JOBS | The job turns VALID as soon as all its inputs are VALID, with no execution. |
ISAUTOFORGET | Boolean | JOBS | The job is automatically forgotten after a certain time after completion. |
ISAUTOKILL | Boolean | JOBS | The job is automatically killed if it exceeds its expected duration. |
ISBARRIER | Boolean | NODES | True if a file has a barrier on it. |
ISBARRIERINVALID | Boolean | NODES | True if a file has a barrier would be INVALID were it not for the presence of a barrier. |
ISCHAIN | Boolean | FILES | True if the file is part of a chain, meaning that there are tools that operate 'in-place' on the file. |
ISDATA | Boolean | NODES | True if node is a file. |
ISEPHEMERAL | Boolean | JOBS | (experimental, do not use). |
ISFILE | Boolean | NODES | True if node is a file. |
ISINTERACTIVE | String | JOBS | True if the job is interactive ( -I -Ir -Il -wl ) |
ISJOB | Boolean | NODES | True if node is a job. |
ISMIGRATABLE | Boolean | JOBS | This field is an annotation to identify jobs that can be migrated. Currently not supported. |
ISNODE | Boolean | NODES | True if a node is a node (Always true) |
ISNONEXEC | Boolean | JOBS | True if a job is not executable |
ISNONEXEC | Boolean | JOBS | True if the job is non-executable. |
ISOPTIONAL | Boolean | FILES | True if an output has the OPTIONAL flag |
ISPLACE | Boolean | NODES | OBSOLETE: True if a node is a file (see ISFILE) |
ISPREEMPTABLE | Boolean | JOBS | This field is honored by the vovpreemptd
daemon. If the value is zero, then the job is not considered for
preemption. For information on how to set the preemptable flag,
see Control Whether a Job is Preemptable. See also
ISMIGRATABLE. |
ISPROCESS | Boolean | NODES | Same as ISJOB. |
ISQUEUED | Boolean | JOBS | The job is ready to fire and in a bucket in the job queue. |
ISREADYTOFIRE | Boolean | JOBS | All inputs of a job are VALID and the job is ready to fire. |
ISSCHEDULED | Boolean | NODES | True if node is scheduled to be retraced. |
ISSCHEDULEDBARRIERINVALID | Boolean | NODES | True if node is scheduled and had the barrier invalid flag set. |
ISSHARED | Boolean | FILES | True if file is shared output. |
ISSKIP | Boolean | JOBS | True if the job is skipped (also called ISAUTOFLOW). |
ISSTDERR | Boolean | FILES | True if file is a stderr file. |
ISSTDOUT | Boolean | FILES | True if file is a stdout file. |
ISSUBJOB | Boolean | JOBS | True if the job is a subjob (e.g. partialtool, vovjobresumer). |
ISSUSPENDED | Boolean | JOBS | True if the job or one of its children is suspended. |
ISSYSTEMJOB | Boolean | JOBS | True if the job is a 'system job' like vovzip, or vovsh -s netinfo. |
ISTOOL | Boolean | NODES | Same as ISJOB and ISPROCESS. |
ISTRANSFER | Boolean | JOBS | True if the job is being transfered to another cluster. |
ISTRANSITION | Boolean | NODES | True if node is job (see ISJOB) |
ISTRIGGERRUN | Boolean | FILES | True if the file has the trigger,run flag, i.e. if a change in the file triggers a retrace of the downcone |
ISTRIGGERSTOP | Boolean | FILES | True if the file has the trigger,stop flag, i.e. if a change in the file triggers a stop of the downcone, followed by a retrace of the downcone |
ISUNSAFE | Boolean | JOBS | True if node is "unsafe" |
ISZIPPABLE | Boolean | PLACES | True if the file can be automatically zipped. |
ISZIPPED | Boolean | PLACES | True if the file is currently zipped. |
IUO | String | NODES | One of the following characters: "." "i" "u" "o" |
JOBCLASS | String | JOBS | The jobclass of a job |
JOBID | String | JOBS | The ID (number) of a job (a field of PROCESSES). An integer but often with leading 0s. |
JOBLOGDIR | String | JOBS | The directory to which the logfile of a job is written (if a logfile is specified on the command line). If no logfile is specified, this is the current directory of the job. |
JOBNAME | String | JOBS | The job name of a job |
JOBPROJ | String | JOBS | Name of the project that the job belongs to (same as project). |
JPP | String | JOBS | Job placement policy. |
LABEL | String | NODES | A short label for the node. |
LASTCPUPROGRESS | Integer (timestamp) | JOBS | The last time the system detected some cpu progress in the job. |
LASTCPUPROGRESSPP | String | JOBS | The pretty-print version of "$NOW-LASTCPUPROGRESS". |
LEGALEXIT | String | JOBS | The legal exit allowed for a job to be considered VALID (same as OKSTATUS). |
LEVEL | Integer | NODES | The level of a node. |
LMHANDLESALL | String | JOBS | A detailed list of all handles that have been matched to this
job. For each handle, the field shows: ResourceName#Tokens
MatchType FLEXlmHandle License:a#1 best 22334
License:b#2 sure 12345 |
LMHANDLESNRU | String | JOBS | A detailed list of all the NRU (Not Requested / Used) handles
that have been matched to this job. For each handle, the field
shows: ResourceName#Tokens MatchType FLEXlmHandle
License:a#1 nru 22334 License:b#2 nru
12345 |
LMRESOURCES | String | JOBS | These are the license resources (typically derived from
FLEXlm features) that appear to be used by a job even if the job
does not explicitly declare them. This field is used by
vovlmremove to decide which features to
remove. The field is updated based on the matching of free
FLEXlm handles and running jobs. The field consists of an even
number of words, with each pair consisting of a resource name
and a boolean flag indicating if the resource is a
"false-out-of-queue", i.e. the handle is not-requested but used.
A handle is Example: License:a#2 0 License:b#1
1 This means that the job requested 2 tokens of
License:a and is in fact using them. In addition, the job is
using 1 token of License:b even if it does not request it. See
also LM_HANDLES_ALL and LM_HANDLES_NRU. |
LX | String | JOBS | Legal Exit Value for a job (Same as legalexit and ok_status). |
MAXRAM | Integer (MB) | JOBS | The max RAM used by a job and its children, in MB. |
MAXSWAP | Integer | JOBS | Maximum amount of swap used by the job, in MB. |
MAXVM | Integer (MB) | JOBS | Maximum amount of virtual memory used by the job, in MB. |
NAME | String | FILES | The name of a file. |
NAMEX | String | FILES | The name of a file, fully expanded. The expansion is done on the server side. |
NODETIMESTAMP | Integer (timestamp) | NODES | The time the node last changed status (i.e. changes color). |
NODETYPE | String | NODES | "FILE" if node is a file, "TOOL" if node is a job (I know, TOOL should be JOB) |
NUMA | String | JOBS | Requested NUMA placement for the job. |
OKSTATUS | String | JOBS | The list of acceptable Exit Status (same as LEGALEXIT). |
OSGROUP | String | JOBS | The operating system group for the job (different from GROUP, which is used in the FairShare scheduling). |
OUTPUTS | Integer | NODES | The number of outputs of a node. |
PID | Integer | JOBS | The process id of a job. |
PRIORITY | Integer | JOBS | Prioity of the job, in the range 0 to 15. |
PRIORITYPP | String | JOBS | Pretty printed version of the priority of the job. |
PROJECT | String | JOBS | Name of the project that the job belongs to (same as jobproj) |
PROP.<propname> | String | NODES | This field is used to access the property with name
propname . For example, to access the
property "ABC", one should ask for "PROP.ABC". See also field
PROPERTIES. |
PROPERTIES | String | NODES | The list of properties attached to a node. The list consists of an even number of words, where the first word is either 'S' (for STRING) or 'I' for INTEGER properties and the second word is the name of the property. See also the 'PROP.*' field |
QUEUETIME | Integer (timestamp) | JOBS | Time the job was put onto the job queue, more specifically the last time the job was scheduled. The job could in fact enter the job queue later due to dependency constraints or to lack of space in queue. |
QUEUEWAIT | Integer (duration) | JOBS | The time a job has waited in the queue, in seconds. |
QUEUEWAITPP | String | JOBS | Pretty-print version of QUEUEWAIT. |
RANDOM | Integer | ALL | A random number in the range [0-9999]. Used, for example, to sort jobs in preemption rules. |
REQCORES | Integer | JOBS | Requested CORES for the job. This is set when the job is dispatched to a tasker. Another name for this field is REQCPUS. See also explanation on REQRAM. |
REQPERCENT | Integer | JOBS | Requested PERCENT for the job. See also explanation on REQRAM. |
REQRAM | Integer (MB) | JOBS | RAM requested by a job. This value may come from 1) the SOLUTION property on the job, if it exists, 2) from the requested resource on the bucket, if the job is queued, or 2) from the resources string of the job. Normally, the value is the same regardless of the origin, but it is possible and acceptable that the value may change due to additional math performed during scheduling. Normal case: a job requests "RAM/200". Then the REQRAM value is going to be 200. Strange case: a job requests "RAM/200 SLOTS/2 RAM/300" (i.e. the RAM request is repeated). In this case, REQRAM will be 200 for the job if it is not Queued or if the SOLUTION property is removed after the execution of the job. Else it will be 500 (=200+300) while the job is Queued. |
REQSLOTS | Integer | JOBS | Requested number of slots for the job. See also explanation on REQRAM. |
REQSWAP | Integer (MB) | JOBS | Requested swap for the job. See also explanation on REQRAM. |
RESERVEDRESOURCES | String | JOBS | DO NOT USE: Only for running jobs |
RESERVEDTOOLS | String | JOBS | DO NOT USE: Only for running jobs |
RESOURCES | String | JOBS | The resources of a job. |
RETRACINGID | String | JOBS | The id of the retracing job (to find the other job is a RUNNING/RETRACING pair). |
RUNSTATUS | String | JOBS | A representation of how well the job is running. Typical values are Good, Paging, NoCpu. Check Job Runtime - Monitor and Profile for more information. |
SCHEDTIME | Integer (timestamp) | JOBS | The earliest time that this job can be scheduled (set with -at or -after option in nc run). |
TASKERGROUP | String | JOBS | The tasker group of the tasker to which the job has been dispatched. |
TASKERID | String | JOBS | The id of the tasker to which the job has been dispatched. |
TASKERNAME | String | JOBS | The tasker name to which the job has been dispatched. |
TASKERSLOTSSUSPENDABLE | Integer | JOBS | Number of suspendable jobs on the tasker on which the job is running. |
TASKERSLOTSSUSPENDED | Integer | JOBS | Number of slots suspended on the tasker on which the job is running. |
TASKERSLOTSUSED | Integer | JOBS | Number of slots used on the tasker on which the job is running. |
STARTDATE | String | JOBS | Like STARTED, only in nice formatted ASCII |
STARTED | Integer (timestamp) | JOBS | The time the job was started, or -1 if the job never ran. |
STATUS | String | NODES | The status of the node. |
STATUSCOLOR | String | NODES | The color associated to the node |
STATUSCONSTRAST | String | NODES | A color that contrasts with STATUSCOLOR. Used mostly in templates for the browser interface. |
STATUSIO | String | NODES | Short version of STATUS. For example, instead of VALID you get 'V' (the name is not very good) |
STATUSMASK | Integer | NODES | (HARD TO USE) a binary mask with a bit set for each value of Node Status. |
STATUSNC | String | NODES | Job Status for Accelerator. |
STOLENRESOURCES | String | JOBS | These are the resources that have been taken away (revoked) from the job, typically because the job has been preempted. |
SUBJOBIDS | String | JOBS | The ids of all subjobs of a job (used for example with distributed parallel jobs). |
SUBMITHOST | String | JOBS | The submission host |
SUBRESOURCES | String | JOBS | Subordinate resources for a job, i.e. the resources after the first '--' token. Used by indirect taskers. |
SUSPENDEDINTERVALS | String | JOBS | The list of all intervals in which the job has been suspended. |
SUSPENDEDTIME | Integer (duration) | JOBS | The total amount of time the job has been suspended (in seconds). |
SUSPENSION | Integer (duration) | JOBS | The same as suspendtime. |
TAIL | String | FILES | The name of the file not incluing the directory path. |
TIMESTAMP | Integer (timestamp) | FILES | The time the file was last modified. |
TIMESTAMPPP | String | FILES | Pretty-printed version of TIMESTAMP. |
TOOL | String | JOBS | The name of the first tool used by the job. |
TOPJOBID | String | JOBS | The id of the top job in a distributed parallel job. |
USER | String | JOBS | The user (or owner) of a job. |
USERXDUR | Integer (duration) | JOBS | The Expected Duration of a job as specified by the user. If negative, the expected duration has not been specified. |
USERXDURPP | String | JOBS | The Expected Duration as specified by the user, pretty printed. |
USESESSIONID | Boolean | JOBS | True if the vovtasker is supposed to look at the session id to find the processes related to this job (in addition to the parent-child relationship). |
WAITREASON | JOBS | A description of why this job is waiting. | |
X | Integer | NODES | The X coordinate of a node. |
XDUR | Integer (duration) | JOBS | The current Expected Duration of a job. It may be set by the user or calculated from the most recent successful completion of the job. If negative, the expected duration is not known. |
XDURPP | String | JOBS | The current Expected Duration of a job, pretty printed. |
XPRIORITY | Integer | JOBS | The execution priority of a job (range 0 to 15) |
XPRIORITYPP | String | JOBS | Pretty-printed version of XPRIORITY. |
Y | Integer | NODES | The Y coordinate of a node (same as LEVEL). |
YOUNG | Boolean | FILES | This field is 1 if the file is younger than any of the jobs that need it. Young nodes are shown with a lighter shade of green in the GUI. |
Z | Integer | NODES | The Z coordinate of a node (always 0). |
ZIPPED | String | FILES | The string 'ZIP' if the file is zipped, or the empty string. |
