Configure a Failover Server Replacement
If a server crashes suddenly, VOV has the capability to start a replacement server on a pre-selected host. This capability requires that the pre-selected host is configured as a failover server.
How vovserver Failover Works
If the vovserver crashes, after a period of time, the vovtasker process on each machine notices that it has had no contact from the server, and it initiates a server machine election.
In this election, each vovtasker votes for itself (precisely, the host that this particular tasker runs on) as a server candidate. The election is conducted by running the script vovservsel.tcl.
After the time interval during which the vovtaskers vote expires, (default 60 seconds) the host that appears earliest on the list will be selected to start a new vovserver.
set ServerCandidates {
host1
host2
host3
ServerCandidates
list. Usually, these vovtaskers have been defined with the -failover
option so they can not accept any jobs, and are members of the
failover
taskergroup. The failover vovserver will read the most-recently-saved PR file from the .swd/trace.db directory, and then read in the transactions from the 'cr*' (crash recovery) files to recover as much of the pre-crash state as possible.
The vovserver writes a new serverinfo.tcl file in the .swd that vovtaskers read to determine the port and host. When it starts, the failover vovserver appends the new host and port information to the $NC_CONFIG_DIR/<queue-name.tcl> as well as to the setup.tcl in the server configuration directory. The vovserver then runs the scripts in the Autostart Directory. This should include the failover.csh script, which resets the failover directory so that failover can repeat. This script removes the registry entry, and removes the server_election directory and creates a new empty one. At the end, it calls vovproject reread to force the failover vovserver to create an updated registry entry.
- For Accelerator, Accelerator Plus, Monitor and Allocator, vovtaskers wait up to 4 days for a new server to start.
- For FlowTracer, vovtaskers wait up to 3 minutes for a new server to start.
After reconnecting to vovserver, vovtaskers automatically exit after all of their running jobs are completed. After the vovserver transitions from crash recovery mode to normal mode, it will try to restart any configured vovtaskers that are not yet running.
- The filesystem holding the .swd directory is unavailable.
- The file servercandidates.tcl does not exist.
- The
ServerCandidates
list is empty. - There is no vovtasker running on any host in the
ServerCandidates
list when the server crashes. - The autostart/failover.csh script file is not in place.
In this case, the failover server will not be automatically started; the server will have to be manually started.
Tips for Configuring Failover
- Make the first failover host the regular one. This way, if the vovserver dumps core or is killed by mistake, it will restart on the regular host.
- Configure special vovtaskers only for failover by passing the -failover option to vtk_tasker_define.
- Test that failover works before depending on it.
Migrating vovserver to a New Host
ncmgr rehost -host NEWHOST
The
specified NEWHOST must be one of the hosts eligible for failover of vovserver.Crash Recovery Mode
Crash Recovery Mode is activated the next time the server is restarted, if the server was not shut down cleanly. Crash Recovery Mode is part of the Failover Server capability of VOV, which is mainly used in Accelerator. This capability allows VOV to start a new server to manage the queue of a server which has crashed unexpectedly.
When you shut down an Accelerator instance cleanly using the ncmgr stop command, the server will save its database to disk just before exiting. When the server is restarted, it will read the state of the trace from disk, and immediately be ready for new work.
Sometimes the vovserver will be stopped unexpectedly, such as due to a hardware problem like a machine crash or memory exhaustion. In such cases, the server will not have a chance to save the project database before terminating.
- In VOV, the main concern is usually the state of the trace, which stores the status all the jobs in your project.
- In Accelerator, there is no trace, and the important thing to preserve is the state of the queue, so jobs do not lose their position and need to be re-queued in the case of a server crash.
Journal Files
The vovserver keeps crash recovery journal files of the events that affect the state of the server. These 'CR' files are flushed whenever the trace data are saved to disk. During crash recovery, the vovserver first reads the last saved state of the trace from the disk data, then applies the events from the CR files.
Crash Recovery Restart
- The server waits for vovtaskers with running jobs to reconnect.
- No jobs are dispatched.
- The server does not accept VOV or HTML TCP connections from vovsh or browser clients.
- At the end, the server performs a global sanity check.
- A crash_recovery_report <timestamp> logfile is written. It logs any jobs lost by the crash recovery sequence.
% vovproject enable <project-name>
% vovproject sanity
