Environment Variables
The following environment variables can be set on Unix and Windows to control certain features within LM-X and the Altair Licensing System.
Variable | Description |
ALTAIR_LICENSE_PATH | Sets the path to the license file or address of the license
server. The format is one of the following:
ALM_PROJECT | Used to report project strings in the transactional logs.
This string will be part of the recorded transaction. The value
set should be 30 characters or less. String may contain valid
characters in the portable filename character set (A-Z, a-z,
0-9, { } / \< > ( ) ` ‘ , ? | [ ] * & ^ $ # @ ! ~ + =).
Any other characters will be URL encoded in the server logs. The
maximum length is 30 characters. This is a client variable.
Note: This will NOT be included in the anonymous log files,
only in the detailed logs.
ALUS_CONF_FILE | Sets the path to the alus.conf file. This must be set prior to starting the license server process. This is a server variable. |
ALM_NO_EXPIRE_WARNING | Setting this value to any non-zero length value will prevent applications from warning users that the license is going to expire. This is a client variable. |
ALM_DONGLE_ENABLED | Setting this to any value will enable a client to use a license dongle. The server is always enabled for dongles. This must be set to enable client dongle support. This is a client variable. |
