Upgrade to a New Release
This upgrade installation scenario expands an existing release by installing a separate set of files that implement a new release of the product.
When you upgrade to a new release, you will need to perform a full install of the new software, and carry forward the files you have changed locally in the current release.
- Follow the upgrade planning directions contained in the next section.
- Download the software to install from the Altair Community website, with guidance from the download information contained in a later section.
- Perform the upgrade software installation, which should require between 15 and 30 minutes depending on disk performance.
- Validate the upgrade by setting your command line environment and running the validation steps.
The following sections will lead you through the steps listed above.
