Download the Software
After the pre-upgrade checklist is complete, you are ready to download the software and prepare the downloaded files in order to do the upgrade to a new release.
Use the Altair Accelerator Product Administrator Account
Log in to your computer, into your Altair Accelerator Administrator account. This is the user that was set up to do the standard install, and who owns all the files in the release.
In the following sections, examples will be written as if the user account named rtdamgr is the Altair Accelerator Administrator. If you are installing Accelerator, there is one step in the procedure that must be performed by the root user.
Create or Reuse a Temporary Download Staging Area
Create a staging area to hold the downloaded files. It must be different from the directory where you plan to install the Altair Accelerator software. The staging area may be removed after installation.
Download the Files
- Access the Altair Marketplace and select the product to install.
- Log in using the account you set up as part of the pre-installation planning steps.
- Click the link for the release version you want, and download the appropriate files.
For a UNIX installation, complete the steps
below:
For a Windows installation, complete the steps below:
