Install the Software
You will need to know the path to the current release in order to perform the operations described here. The path that is needed is the one that ends with the release number.
In the examples here, the current installation path will be shown as the /opt/rtda/2019.01 directory. When you see this in examples, you should understand that it is referring to the path to your current installation. The upgrade examples will be upgrading the 2019.01 release to the 2020.1 release. The upgrade install will be installing files into the /opt/rtda/2019.01 directory.
