Clean Up
Now that you have performed a verified install of the platform-specific files for an added platform, you may be done.
However, if your early checking showed that there has been a software hotfix published in this release, for the added platform, then you are not done. You will need to go on to the chapter on how to "Install Patch to Current Release" and install the software hotfix for the platform.
Remember, investigate the state of the current release with regard to the published software patch level.
Has the software patch level already been applied to the current release? If so, then you will be installing the software patch for just the added platform. If not, they you will want to consider installing the software patch level to the entire release and have the software hotfix for the added platform be covered by doing the full software patch update.
