Start a Test Queue
At a given site, a single queue is recommended, such as a single Accelerator setup, by default called "vnc". Such a setup is called a cluster by other systems. The scheduler in Accelerator does not have queues in the sense used by other batch systems.
In this tutorial, you will start a temporary Accelerator queue for our testing. This allows you to experiment with most of the administration tasks without disturbing your production Accelerator queue.
Find the Server Working Directory
$VOVDIR/../../vnc/vnc.swd
This directory contains the server configuration files and server/tasker logs, etc.
Start a Queue
The command to start a queue is ncmgr start. By default, this command will start the default queue in the directory of $VOVDIR/../../vnc.
Use a Specific Queue
Now that you have started a new queue, you have at least two Accelerator queues in your system. There are two ways to use a particular queue.
