In the following User Tutorials, you will experiment with Accelerator on most topics that a user would be most interested
in, including submitting jobs, tracking job information, analyzing and solving common problems, etc.
In the following tutorial, you will experiment with most issues that an Accelerator administrator will need to address, including starting/stopping the server, configuring FairShare, resources, taskers and environments.
The purpose of this tutorial is to guide one through the creation and use of a small FlowTracer project using a combination of the Command Line Interface (CLI) and the Graphical User Interface (GUI).
You can run the flow by pressing Run in the action menu
bar in the top of the Set Viewer panel.
Nothing will happen since the very first job in the dependency graph is
unable to run since its input aa is missing.
Create a file aa in the simple_test
directory.
% touch aa
The graph will change to show that file aa was just
created. If this is not seen, make sure that the Set Viewer is actively
displaying the System:nodes set by double clicking on the
System:nodes choice in the Set Browser.
The node
for file aa is green. The rest of the nodes are purple
to indicate that all those dependent elements are INVALID. Another way to
see the INVALID set of nodes it to say they are ready to run.
Click Run to have FlowTracer process
the graph.
The display will change quickly to reflect the various state changes of
the nodes representing the jobs and the files.
You will see nodes change to
light blue to indicate they are SCHEDULED, or yellow to indicate they are
RUNNING, and finally, all of the nodes will turn bright green to show a
successful run of the dependency graph. All the dependent jobs ran
successfully and all dependent files were made successfully. This is just an
emulation using the cp command but if the defined jobs
had used production class programs, the result would be the same.
Running a job interactively is fun to do but it is not how
FlowTracer would be used in production. This section was to show
you how the flow description language file is created and how the flow is registered
with FlowTracer by using vovbuild.
