Example Application: REST 101
Programs that use the Accelerator REST API can do so in two ways. The preferred approach is to utilize the Python library module "vov_rest_v3", which is provided with Accelerator software packages in the file vov_rest_v3.py. This Python module simplifies coding by hiding details of the HTTP operations that interface directly to the low level REST API. The vov_rest_v3 module requires Python version 3 or higher.
- Management of JWT access tokens
- Policy of your application regarding insecure HTTPS configurations
- Control over the use of connection "keep-alive"
To get a quick start using REST, examine a simple "REST 101" example Python program that queries REST to return the name of an NC queue, shown below. The lines of the program are numbered and annotated with explanations.
1 #!/usr/bin/python3
2 #
3 # nc_rest_101.py
4 #
5 import os, sys, getpass, json
6 import vov_rest_v3
7
8 url = os.environ['NC_URL']
9
10 vrest = vov_rest_v3.VOVRestV3()
11 vrest.authorize(url, getpass.getpass('Password:') )
12 r = vrest.submitRequest("GET", url + "/api/v3/project/1/project")
13
14 print ( json.dumps(json.loads(r), indent=2) )
- Line 1
- This Python program is compatible with Python 3.
- Line 6
- Import the vov_rest_v3 Python module that comes with the Accelerator product. Copy it locally from $VOVDIR before running the Python program.
- Line 8
- Pull the URL for the NC queue out of an environment variable. The URL is what nc cmd vovbrowser shows.
- Line 10
- Allocate vrest, an instantiation of the VOVRestV3 Python class.
- Line 11
- The authorize() method function authenticates using
the password and allocates a JWT token stored in the object. This
example obtains your user password by interactive prompt.Note: This example uses username/password authentication. To use key-based authentication, see .
- Line 12
- The HTTP get request is sent, returning a string containing the HTTP response data in JSON format.
- Line 14
- The HTTP response string is parsed into JSON and pretty-printed.
% echo $NC_QUEUE
My_NC_QUEUE
% export NC_URL=`nc cmd vovbrowser`
% echo $NC_URL
http://myhost:6330
% cp $VOVDIR/scripts/python/vov_rest_v3.py .
% python3 nc_rest_101.py
Password:
"startrow": 1,
"endrow": 1,
"query": "SELECT project FROM 1",
"errormsg": "",
"columns": [
"col": 0,
"field": "project"
"rows": [
"My_NC_QUEUE"
Example Applications: Job Submit and List
To demonstrate the utility of the REST API, here are two simple Python programs that imitate the function of the nc run and nc list commands that are familiar CLI tools from the Accelerator product. The source code for these tools, named nc_run.py and nc_list.py, is found on the following pages.
These REST programs only require that the NC_URL environment variable be set to the Accelerator queue URL, as returned by nc cmd vovbrowser. Here is a terminal image that demonstrates the simple REST tools.
% export NC_URL="`nc cmd vovbrowser`"
% ./nc_run.py sleep 33
Password:
New job is 45080
% ./nc_run.py sleep 66
Password:
New job is 45083
% ./nc_list.py
Password:
ID STATUSNC PRIORITYP HOST COMMAND
000045080 Running normal myhost vw sleep 33 > JOBLOG.185633
000045083 Running normal myhost vw sleep 66 > JOBLOG.903723
nc_run.py
#!/usr/bin/python3
# nc_run.py
# Usage
# export NC_URL=<URL FOR NC QUEUE>
# ./nc_run.py <command> [args]
import os, sys, random, json, getpass
import vov_rest_v3
def getMyPassword():
return getpass.getpass('Password:')
# Main body
nc_url = os.environ["NC_URL"]
scheme = nc_url.split(":")[0]
hostport = nc_url.split("/")[2]
url = "{0}://{1}".format(scheme, hostport)
command = " ".join(sys.argv[1::])
vrest.authorize(url, getMyPassword())
# Job attributes - required
VOV_JOB_DESC = {
"command" : command,
"logfile" : "JOBLOG." + str(random.randint(100000,999999)),
"rundir" : os.getcwd(),
"env" : "BASE",
# Job attributes - optional / User specified
VOV_JOB_DESC.update( {
"priority,sched" : 4,
r = vrest.submitRequest("POST", url + "/api/v3/jobs", jsonData=VOV_JOB_DESC)
print ("New job is %s" % json.loads(r)["jobid"])
nc_list.py
#!/usr/bin/python3
# nc_list.py
# Usage
# ./nc_list.py
import os, sys, json, getpass
import vov_rest_v3
def listJob(vr, url):
query = ( url + '/api/v3/query'
+ '?select=id,statusnc,PRIORITYPP,host,command'
+ '&from=System:User:' + os.environ['USER'] )
response = vr.submitRequest("GET", query)
return response
def prettyPrint( text ):
dd = json.loads(text)
for ii in range(0, len(dd['columns']) ) :
sys.stdout.write("%9.9s " % dd['columns'][ii]['field'])
sys.stdout.write("\n")
if ('rows' not in dd):
return
for rr in range (0, len(dd['rows']) ) :
row = dd['rows'][rr]
if (ii < len(dd['columns'])-1):
sys.stdout.write("%9.9s " % str(row[ii]))
else:
sys.stdout.write("%10.30s" % str(row[ii]))
# Main body
nc_url = os.environ['NC_URL']
json_text = listJob(vrest, url)
prettyPrint(json_text)
