Job Control
Accelerator provides several commands of job controls, including wait, stop and forget.
Wait for Jobs
- Get usage help
% nc wait -h
- Wait for a job
% nc run sleep 10 Resources= linux Env = D(VOV_ENV_SOURCE=vnc_logs/envdexin36362.env) Command = vw vwrap sleep 10 Logfile = vnc_logs/20021231/140024.23307 JobId = 04213283 nc: message: Scheduled jobs: 1 Total estimated time: 0s % nc wait 04213283
- Wait for all jobs in current directory
% nc wait -dir . nc: message: Job 04193913 is already FAILED nc: message: Job 04193915 is already FAILED nc: message: Job 04193917 is already FAILED nc: message: Job 04193919 is not scheduled nc: message: Job 04194308 is not scheduled nc: message: Job 04211259 is already FAILED nc: message: Job 04211268 is not scheduled nc: message: Job 04213283 is already VALID nc: message: Job 04213297 is already VALID nc: message: Exiting with status 2 (Failed jobs)
- Wait for all jobs using tool spice
% nc wait -select "tool==spice"
Forget Jobs
- Get a list of jobs
% nc list 04146420 Done sleep 1 #in the form of "jobId status command" 04146425 Done sleep 5 04146427 Running sleep 10 04146429 Running sleep 15 04146431 Queued sleep 20 04146433 Queued sleep 60
- Forget some of them
% nc forget 04146420 04146425 nc: message: Forgetting 2 jobs
- List jobs again (notice those two are gone)
% nc list 04146427 Done sleep 10 04146429 Done sleep 15 04146431 Done sleep 20 04146433 Done sleep 60
- Forget all my jobs
% nc forget -mine nc: message: Forgetting 4 jobs
Stop Jobs
A job can be stopped when it is either Running or Queued. Stopping a job does not forget it from the server database. "Running" jobs will exit, and "Queued" jobs will be dequeued when you stop them.
- Stop some jobs
% nc run sleep 60 Resources= linux Env = D(VOV_ENV_SOURCE=vnc_logs/envdexin36362.env) Command = vw vwrap sleep 60 Logfile = vnc_logs/20021231/140803.23386 JobId = 04213393 nc: message: Scheduled jobs: 1 Total estimated time: 0s nc stop 04213393 nc: message: Stopping RETRACING job 04213393
- Stop all my jobs
% nc stop -mine nc: message: Stopping RETRACING job 04146627 nc: message: Stopping RETRACING job 04146629 nc: message: De-queuing job 04146631 nc: message: De-queuing job 04146633
