Joint Configuration for Parsing Debug Logs – File-Based Configuration
To add denial data from a debug log to an existing tag (joint configuration), perform the following steps:
- Go to the command line interface.
- Go to the path/to/licmon.swd – go to the licmon swd/vovlmd.
- Edit the config.tcl file and edit the tag.
Add
-debuglog </path/to/log>
. - Save the file.
