Standalone Configuration for Parsing Debug Logs – File-Based Configuration
To add denial data from a debug log to an existing tag (standalone configuration), perform the following steps:
View new features for Monitor 2024.1.0.
A real time software license monitoring and management tool.
Currently there are no Monitor tutorials available.
This manual describes the web user interface and provides instructions on common uses and best practices for users. It also provides the basic setup, installation and management practices for administrators. For both administrators and users, it functions as a getting started guide.
Monitor monitors tools with licenses using live sampling and debug logs for denials, and it monitors tools with no licenses using wrapper scrips and a monitoring agent.
All Altair Accelerator software products are based on a client/server architecture and have three main components: a server, daemons and taskers.
There are four different types of installations available for Monitor.
We suggest as first steps that you check Monitor to be sure it’s running properly and then perform a few basic tasks to get a feel for the system.
This section explains how to use Monitor to answer common questions. In most cases, there isn’t one answer to a question. Some investigation is required.
Monitor has many views and reports, and this section details all of them. It is designed as a reference, so when you generate a report, you will understand all its parameters.
This section is organized into a series of instructions designed to guide you through the beginning steps of setting up your Monitor system.
Answers to common questions when using Monitor.
Altair Monitor is a software license tracking tool that reports current and historical license utilization. The license managers that Monitor supports includes FlexNet Publisher, Reprise, LUM, and many others. The primary user interface for accessing Monitor is a web interface.
Add_DEBUG_LOG </path/to/log> -tag <TAG> [options]
add_DEBUG_LOG
[options]
Add_DEBUG_LOG </Users/ybouvron/rtda/Cadence/@DATE@.log> -tag
CAD_LOG -tz PST8PDT -minPeriod 12h -maxPeriod 1d -autokill
2h
Copyright (c) 1994-2023. Altair Engineering, Inc. All Rights Reserved. Contains trade secrets of Altair Engineering, Inc. Copyright notice does not imply publication.
