Initial Setup
It is *strongly* recommended that you begin with a working simulation environment (correct paths, model files, etc.).
- Start virtuoso and bring up the simulation environment.
- Choose Options > Job Setup and bring up the Job Policy Setup form.
Setup the policy as follows:
- Select the NC Default job policy.
- Set Job Class to a suitable Accelerator jobclass. The default is 'cadence_ade'.
- Optional: Change Job Name. In this field you can use the symbolic values @ID@ and @USER@ (but not the @JOB@ value, as in ADE-5)
- Choose Max. Jobs appropriately. The default is 2. This number determines how many parallel jobs you want to run.
- If desired, change the job policy name and save the job policy to disk. To do this, enter a Job Policy Name to anything you like. (The name will be remembered when you run tests.)
Click Save and save in one of the locations
shown (typically .cadence/jobpolicy, this is
dictated by the value of setup.loc in your
installation).
- Click OK.
In the Run Options dialog, select the Parallel
option.
- Try running a single simulation to test the setup.
