Install Cadence
- Check that the VOVDIR environment variable is set correctly. You should be able to locate the following file: $VOVDIR/eda/Cadence/ADE-NC/cdsinit
Update your ~/.cdsinit file. The simplest change is to add
the following lines:
;;; Append these lines to ~/.cdsinit ;;; Sourcing RTDA cdsinit vovdir = getShellEnvVar( "VOVDIR" ) ilfile = strcat( vovdir "/eda/Cadence/ADE-NC/cdsinit" ); printf( "Loading RTDA NetworkComputer Interface %s\n" ilfile ) load( ilfile )
