Log Files
- Server log files in *.swd/logs
- Alert log files in *.swd/logs
- Journal files in *.swd/journals
- Jobs files in *.swd/data/jobs
- Resources files in *.swd/data/resources
- Taskerload files in *.swd/data/taskerload
- Waitreasons files in *.swd/data/waitreasons
- Checkouts files in *.swd/data/checkouts (this applies only to Monitor)
- Denials files in *.swd/data/denials (this applies only to Monitor)
The files are closed after midnight and a new file is opened for the next day with the appropriate name.
@LOGFILE@
is the full path of the log file.@EXPIRE@
is the expiration timestamp for the log file, typically midnight of the current day.
vovloghandler: This script is an example of a log handler to be used with dailylogs
vovloghandler: It is used to start a process to monitor the logs
vovloghandler: and to process them as they get generated.
vovloghandler: In this example, we use a simple 'tail -f ...'
vovloghandler:
vovloghandler: Usage: vovloghandler @FILENAME@ @EXPIRE@
vovloghandler:
- The expiration time has been reached.
- A file called
@FILENAME@.closed
;@FILENAME@
is substituted with the full path to the log file.# # This is a fragment of policy.tcl # # Example of flags to control which handlers are called for the log files: # set config(logs,server,handler) "" set config(logs,journals,handler) "" set config(logs,jobs,handler) "vovloghandler @FILENAME@ @EXPIRE@" set config(logs,resources,handler) "" set config(logs,waitreasons,handler) "" set config(logs,checkouts,handler) "vovloghandler @FILENAME@ @EXPIRE@"
Old logs can be cleaned up using vovcleanup.
Compress Log Files
vovcompresslog: Usage: vovcompresslog <LOGNAME>
config(log,XXXX,compress)
flags.
Example:#
# Example of flags to control which logs get compressed.
set config(logs,server,compress) 0
set config(logs,journals,compress) 1
set config(logs,jobs,compress) 0
set config(logs,resources,compress) 1
set config(logs,waitreasons,compress) 0
set config(logs,checkouts,compress) 1
Reopen the Logs After an Error
% vovsh -x 'vtk_server_config reopenlogs 1'
