Sanity Check for vovserver
The command sanity is used to perform checks on the consistency of the trace and of other internal data structures.
% vovproject sanity
Use the reread command to re-read the server configuration. The files read are policy.tcl, security.tcl, equiv.tcl, setup.tcl, and exclude.tcl.
% vovproject reread
- Clears all alerts
- Flushes journal and crash recovery files
- Clears IP/Host caches
- Stops and restarts resource daemon (vovresourced)
- Checks and cleans internal object attachments
- Verifies all places and jobs have sensible status
- Resets user statistics and average service time
- Checks the contents of system sets like System:jobs
- Removes older jobs from recent jobs set
- Makes sure all jobs in the running jobs set are actually running
- Verifies all sets have the correct size
- Clears the barrier-invalid flag on all nodes and recomputes it
- Clears empty retrace sets
- Checks preemption rules
- Checks all tasker machines, marking them sick if they are not responding
- Checks for rebooted tasker machines and terminates jobs attached to them
- Checks filesystems on tasker machines and verifies mount points
- Clears resource list caches from jobs
- Clears and rebuilds job class sets
- Creates limit resources for ones that are missing
- Verifies grabbed resources (non running jobs should not have any)
- Makes sure only running jobs have stolen resources
- Reserves resources for all running jobs
- Create any missing resource maps for groups and priorities
- For each job with I/O, makes sure outputs are newer than inputs
- Makes sure any file with running status has an input job with running status
- Verifies the status of all nodes
- Checks for stuck primary inputs (primary inputs should only be VALID or MISSING)
- If a file is invalid or missing, but the input job is VALID, turn the job INVALID
- Finds running jobs without tasker and changes the status to SLEEPING
- Makes sure all input files of a VALID job are also VALID
- Makes sure all output files of a job have the same status as the job
- Recomputes waitreason counts
- Checks job queue buckets
- Verifies link between job queue buckets and resource maps
- Makes sure all queued jobs have job queue buckets
- Checks FairShare groups
- Checks for a license
