Search the Preferences
Search for a setting to show the closest match in the Preferences window. Or use the API to display selectable search results in a dropdown list.
In the search bar, type a keyword. The closest match is shown in the
Preferences window.
Tip: Via the API, you
can switch between the default filter search mode (above) and the dropdown
search mode. In dropdown search mode, as you type a keyword in the search
bar, a dropdown list appears, displaying all search results. Select the
desired setting from the dropdown list to locate it in the Preferences
window.
- To switch between filter and dropdown search modes:
void PreferencesDialog::SetSearchMode(PreferencesDialog::SEARCH_MODE searchMode) - To turn on dropdown search mode:
PreferencesDialog::SetSearchMode(PreferencesDialog::POPUP) - To turn on filter search mode:
PreferencesDialog::SetSearchMode(PreferencesDialog::FILTER)
