Preferences: Sketching
Define preferences for sketching.
Sketching
| Preference | Description |
| Auto-Align Axes | Automatically align the Y axis vertically in any new sketching plane. When this option is turned off, the sketch plane will be rotated to the closest principal axis instead. |
| View Along Sketch Normal | Automatically align the sketch plane. |
| Orthographic Projection at Creation | Automatically switch to orthographic projection when entering sketch mode, and return to the previously selected projection tool when existing sketch mode. |
| Hide Sketch Plane After Sketch Creation | Show or hide the sketch plane. |
| Show Legend | Show or hide the legend in the workspace. |
| Show Constraint Toolbar | Show or hide the Constraint Toolbar in the workspace. |
| Show Grid | Show or hide grids. |
| Show Closed Regions | Shade the closed regions of the sketch profile. |
| Show Points | Show or hide points. |
| Show Center Points | Show or hide center points of circles or arcs. |
| Show Constraints | Show or hide constraints when in sketch editing mode. |
| Show Dimensions | Show or hide dimensions when in sketch editing mode. |
| Show Variable Names in Dimensions | Show or hide the names of variables in dimensions. |
| Show Construction Lines | Show or hide construction lines when in sketch editing mode. |
| Show Construction Aides | Show or hide the construction aides used in the Polyline tool. Enabling this option allows you to specify x- and y-coordinate values. |
| Show Intersection Curves on Sketch Plane Creation | Show or hide intersection curves when you create a sketch plane. |
| Default Fillet Radius (m) | Define the default fillet radius for sketch geometry. |
| Sketch Plane Transparency (%) | Define the percent transparency of parts in the modeling window while in sketch mode. |
| Constraint Display Size | Define the size of the constraint icons in the modeling window. |
| Grid Spacing (m) | As you zoom in and out of a sketch plane, the grid spacing changes. Define the smallest and largest grid size based on the selected metric or imperial display units. |
