OptiStruct Interface
New Features
- General axisymmetric CQAXIG/CTAXIG elements support has been added.
- Plane Stress analysis has been added.
- Strain life EN curve plot option from browser Material view for MATFAT materials has been added.
- New Mass Balance Workflow has been added. The Mass Balance tool can be used
                        to automatically distribute masses on nodes or properties, to match
                        user-defined target mass and CoG of selected properties.Figure 1.
Enhancements
- 3D Rotor definition has been enhanced.
- Slipring joint type support has been added in JOINTG elements.
- Include Tied Contact and Rigidbodies support options have been added in Find Attached.
- Nonlinear shape desvar creation through controllers has been added from the Optimize ribbon under Design Variables drop-down menu.
- New convection CONVG set as default option has been added in the Convection ribbon.
- Multiple TICA definition within a load collector has been enhanced.
Resolved Issues
- The problem with incorrect export of MAT9OR material card has been resolved.
- The problem with incorrect continuation line when PJOINTG defined with Friction option has been resolved
- You are now able to edit values of DTABLE card from Entity Editor.
- The problem with inconsistent visualization of MONPNT3 has been resolved.
- The Measure tool Moment of Inertia sign convention has been corrected.
