Fix Mesh Quality of Tessellated Models
Use the Fix tool to improve the quality of an FE (discrete/mesh) model.
From the Mesh ribbon, click the arrow next to the Mesh
tool set, then select Fix.
On the guide bar, click
to define the criteria for
quality improvements.
- Select the surfaces to fix.
- Click Fix on the guide bar.
Note:
- All selected cleanup operations are performed in sequence using the same order listed in the options menu.
- If you have a CAD geometry model with mesh and you want to improve its quality, first convert it to an FE model using the Convert tool.
