Generate a Mesh Quality Report
Use the Quality Report tool to check the quality of surface and volume mesh.
From the Mesh ribbon, click the Quality
Report tool.
A report dialog opens. - Switch to the Count tab to review the count of the mesh and each element type.
- Switch to the Surface Mesh Checks tab to view surface mesh quality checks and activate/deactivate desired checks.
Switch to the Volume Mesh Checks tab to view volume mesh
The worst value column helps you to understand where the worst quality cell is.
- Click Calculate to populate the tables.
- Optional: Click Export to export the quality check report.
