Specify Heat Exchangers
Identify the inflow, outflow, inertial resistance, and viscous resistance of heat exchangers, which are modeled as a porous medium.
Identify the heat exchangers in one of two following ways: as a series of
in/out surfaces or as a single solid. Setting up a single solid heat exchanger is
more straightforward but requires you to define the permeability
direction.
Use the Identify Heat Exchanger tool. You can
choose to define each part of the heat exchanger solid, or define the solid as a
whole. To define the heat exchanger using in/out surfaces:
- Right-click on a part in the modeling window or the Model Browser and select from the context menu.
- Select a part in the modeling window or the Model Browser then change the Identify As field to Heat Exchanger Inlet/Outlet/Wall in the Property Editor.
To define the heat exchanger as a whole solid:
Tip:
- Open the Property Editor and review the parameters associated with a particular heat exchanger by left-clicking on parts identified as a heat exchanger in the Model Browser. Heat exchanger properties that can be set include: Inertial Resistance and Viscous Resistance, and Permeability Direction
- Define additional heat exchangers by clicking
in the Heat Exchangers dialog. This will increase an internal index to number all heat exchangers.
- Use the right-click context menu in the Heat Exchangers dialog to delete and rename heat exchangers.
