Review Mesh Controls and Import/Export Templates
Review and edit all of the refinement zones in your model and import/export mesh control templates.
From the Setup ribbon, Mesh Controls tool group, click the Zones tool.
The Mesh Controls dialog opens and displays any refinement zones and their properties.Figure 2.
- Optional:
Click
to import a mesh controls
template saved from a previous session.
Note: When importing a template, the names of the parts referenced in the .xml file need to match the part names in the current geometry, otherwise their properties won't be mapped. - Edit the properties and active state for any refinement zones.
- Optional:
Click
to export mesh controls
as an .xml template file.
Tip:
- Sort columns by clicking on a column title.
- Change the columns that display in the Mesh Controls dialog by right-clicking on a column title. In the Property dialog, enable the corresponding check boxes of the columns you wish to display.
