Safety Tools
Use the Safety ribbon to access crash and safety post-processing tools.
Vehicle Crash Regulation Tools
- Load Case > Front Impact
- From the Load Case group, click the arrow next to the front impact icon,
, to select the following tools:
- IIHS Front (40%)
- IIHS Front (25%)
- MPDB (HyperView only)
- Load Case > Side Impact
- From the Load Case group, click the IIHS Side icon,
, to display the tool.
- Load Case Menu
- From the Load Case drop-down menu, select the following post-processing
tools:
- Compare Time History
- Door Intrusion
- Relative Displacement
Vehicle Impact Regulations Tools
From the Impacts group, you can access the following tools:
- Click the Pedestrian icon,
, to access the pedestrian impact post-processing tools for head, lower-leg, and upper-leg simulations analysis in accordance with Euro-NCAP, GTR, and C-NCAP regulations.
- Click the Instrument Panel icon,
, to access the post-processing tool for FMVSS201 and ECE-R21 regulations.
Dummy Injury Criteria
From the Occupant group, select the Clip drop-down menu to
access the Injury Criteria plot macros.
Note: This option is
only available in HyperGraph.
