The automotive solution in MotionView provides a comprehensive
vehicle library of Cars, Trucks and Motorcycles that can be used to simulate suspension
behavior and full vehicle dynamics.
The vehicle library allows you to build different vehicle components and suspension
combinations for various types of automotive applications. Suspensions and sub-systems not
covered in the library selections can typically be built by modifying an existing library
suspension.
Car/Small Truck Library
Heavy Truck MDL Library
Two-Wheeler MDL Library
Note: You can also create your own library of vehicles and
standard events that match your corporate processes and methods. The
User/Custom Library option can be used for this purpose.
The
vehicle library is intended to provide a good starting point in the design of vehicles.
The models contain generic data. You are responsible for populating the model with the
appropriate data, such as suspension geometry, spring and damper parameters, mass and CG
location, bushing data, tire and road data, and other model information that is required
to develop an accurate vehicle model.
The vehicle libraries can be accessed by loading the MBD-Vehicle Dynamics
Tools under the Preference File, Figure 1.
and then selecting the library in Model > Set Wizard PathsFigure 2. Figure 3.
