The Design Explorer Browser displays a hierarchical view of your
design setup and can be used to enable and disable exploration parameters.
From the Design Explorer ribbon, Exploration tool group, click the
Design Explorer tool.
The Design Explorer Browser opens in the browser
area.
Any defined parameters are displayed here. Multiple explorations may
be created in any given HyperMesh session. Use
the Enabled option to select the active exploration and include or exclude
desired design variables, responses, objectives, or constraints before
evaluating.
Note: Only one exploration can be enabled at a
time.
